Group: DynoMotion Message: 7261 From: Jing Zhang Date: 4/15/2013
Subject: Separate Enabling of Motors
Hi, Tom,
I am using a combination of KFlop+KStep, and I find that once one motor is enabled to work, the other three motors have voltage on.
If I use one motor for a longer time, the other three motors have the trouble of overheating. How could I just enable the motor which needs to work?
Best
Jing
Group: DynoMotion Message: 7262 From: Tom Kerekes Date: 4/15/2013
Subject: Re: Separate Enabling of Motors
Hi Jing,
Sorry that was a design choice on KSTEP in order to reduce the number of I/O required there is just one enable.  Normally a system must be designed so that if a motor is used continuously it will not overheat anyway.  You may need to reduce the current settings for your motors or add more heat sinking for them.
Group: DynoMotion Message: 7265 From: Jing Zhang Date: 4/15/2013
Hi, Tom,
For the current setting, could you give me some example as how to reduce the current settings? I have already limited the current to the minimum value with current setting jumpers.
Best
Jing
Group: DynoMotion Message: 7266 From: Tom Kerekes Date: 4/15/2013
Hi Jing,
If you have removed all the jumpers that is the lowest setting.  Your motors must be very small.  What are their specs?
Group: DynoMotion Message: 7267 From: Jing Zhang Date: 4/15/2013
Hi, Tom,
Yes, the motors are small.
The motors I use are EAD LH1715-12. The phase voltage is 12 volts, and the phase current is 0.4 A, the phase resistance is 30 ohms.
Best
Jing
Group: DynoMotion Message: 7268 From: Tom Kerekes Date: 4/15/2013
Hi Jing,
The current rating is too small for KSTEP.  If you chose a lower voltage motor winding option like the LH1715-M100 (1 Amp 4.7 ohms) it would work and you would get much higher speed and torque.
Group: DynoMotion Message: 7270 From: Jing Zhang Date: 4/15/2013
Hi, Tom,
That is true. I have the other motors already. Is there anything I can do with the small motors?
Best
Jing
Group: DynoMotion Message: 7272 From: Tom Kerekes Date: 4/15/2013
Hi Jing,
Not really without going to different stepper drives.
Group: DynoMotion Message: 7273 From: Jing Zhang Date: 4/15/2013
Thanks.
Is there anyway I can do PWM to reduce the current in those spare motors?
best
Jing
Group: DynoMotion Message: 7274 From: Tom Kerekes Date: 4/15/2013
Hi Jing,
Not really.  To be honest we made a mistake when we designed KSTEP and used an opto coupler that was too slow for the Enable (and the Enable/Disable times are asymmetric).  So the PWM frequency must be very low (<1KHz) which will result in an annoying sound and not work while moving.
I suppose you could add a dummy shunt inductive load to divert some of the current.
You should be able to replace these small motors very inexpensively.  Here is a much better motor for $20:
http://www.kelinginc.net/NEMA17Motor.html
Group: DynoMotion Message: 7275 From: Jing Zhang Date: 4/15/2013
Hi, Tom,
Thanks a lot for your suggestion.
Best
Jing
Group: DynoMotion Message: 7276 From: tmday7 Date: 4/15/2013
Kelings new website has a little better price, if that helps.
http://www.automationtechnologiesinc.com/products-page/nema-17
Troy
> From: Jing Zhang <jing_usc@...>
> Sent: Monday, April 15, 2013 4:41 PM
> Subject: Re: [DynoMotion] Separate Enabling of Motors
> Hi Tom,
> Thanks.
> best
> Jing
> From: Tom Kerekes <tk@...>
> Sent: Monday, April 15, 2013 4:36 PM
> Hi Jing,
> Sent: Monday, April 15, 2013 4:23 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 3:48 PM
> Hi Jing,
> Sent: Monday, April 15, 2013 3:12 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 3:06 PM
> Hi Jing,
> Sent: Monday, April 15, 2013 2:44 PM
> Hi, Tom,
> Best
> Jing
> Sent: Monday, April 15, 2013 11:59 AM
> Hi Jing,
> Sent: Monday, April 15, 2013 11:20 AM
> Subject: [DynoMotion] Separate Enabling of Motors
> Hi, Tom,
> Best
> Jing
